Author Topic: suggestions?  (Read 1649 times)
Offline vwchloe
suggestions?
« on: 08 August 2008, 17:47 »
Hi,
i'v recently noticed a slight cracking noise coming from one speaker in the back, the person who had the ar before me has put 6x9 pioneer speakers and has used a kind of sound velt material.
I have no idea about speakers and i wondered if you had any suggestions on what might be making the noise. Or a good forum or topic that might have options.
I have check that there is no crack in the speaker.
Many Thanks Chloe  :smiley:
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
Re: suggestions?
« Reply #1 on: 15 August 2008, 04:48 »
loose wire?? or perhaps the speaker is out of phase....as in positive is on negative instead and vice versa!? Are they amped or running directly from the head unit? if directly from head unit, then possibly a fault with a loose/tempramental wire. failing that..whilst the speakers are on and working..push the crackling one down from the cone with your hand and check to hear if it continues to crackle then? if it stops and is sounding relatively clean..within reason as your hand is on it..then it may just be a problem with that speaker!
Try switching the 2 pos and neg wires from one 6x9 speaker to the other and see if the problem happens with the other good sounding speaker...if so..then definate wiring issue. if it sounds ok..then the other initial bad sounding speaker has gone faulty! Hope that helps!
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
