Author Topic: 1.3 into my clipper????  (Read 3134 times)
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
« on: 08 May 2008, 15:44 »
Was thinking of fitting a 1.3 motor and five speed box out of a mk2 golf. The clipper previously had a 1.8 carb with auto box. I know the rack and some wiring is different to that on a manual. But, is the main carb, dizzy wiring the same?
Offline 10:27
Re: 1.3 into my clipper????
« Reply #1 on: 10 May 2008, 11:12 »
sorry fella why would you put a 1.3 engline in a clipper? i'm guessing the negine dead in your clipper but why not just source an engine from a driver or another clipper cabriolet?
Offline dan7
« Reply #2 on: 10 May 2008, 15:12 »
I know what you're saying, but i bought the car with no engine or box, was an auto. Due to escalating fuel/tax/insurance costs, i'm contemplating smaller engine.
Offline 10:27
« Reply #3 on: 10 May 2008, 19:01 »
awww i understand fella it just that a 1.3 in a clipper is going to be very slow because the car is quite heavy compare to a tintop mk1! i have seen a clipper with a lupo engine in and that worked quite well but he did have to change the dash etc and it ended up being quite a lot of work
Offline [han]
  • Graphic Designer for Haribo
« Reply #4 on: 16 May 2008, 18:17 »
i agree with the above, cabs are slightly heavier than tip tops, maybe see if you can get someone to take you out in a 1.3 tin top to see.
the clippers are cheaper to insure than the gti i understand. so it shouldnt be that bad.
Sounds like a lot of effort too!!!!
Offline dan7
« Reply #5 on: 16 May 2008, 20:33 »
Update! Just been offered a 1.6 petrol engine and gearbox out of a mk1 Caddy for £100, so probably go for that instead!!!
Offline kraM
  • It's not the speed, it's the sudden stops...
« Reply #6 on: 20 May 2008, 21:35 »
Get the pedal box too, as you'll really struggle to change gear without a clutch pedal, also, get the
re-inforcing plate for the clutch cable to bulkhead.
It's not the speed... it's the sudden stops...
