Author Topic: Heres the install  (Read 6355 times)
Offline gribsymk3
Heres the install
« on: 09 November 2007, 13:25 »
Im installing a new system in my mk3, any opinions or advice welcome
Head unit: Alpine DVA-9861
Components 2 front 2 rear: Rainbow SLC265 100w RMS
Amp for speakers: Alpine MRP-F550 4 Channel 90w RMS
Sub: Alpine Type R 1242D 500w RMS
Amp for sub: Alpine mono MRPM650 600w RMS
Sub box: Alpine ported RS12V
What do you think this will sound like opinions appreciated!
Offline Uruk Hai
Re: Heres the install
« Reply #1 on: 09 November 2007, 18:01 »
Its not the kit but how its fitted that decides how it will sound but if you do a good job and use a bit of well placed sound proofing it should sound rather nice, good luck with the install  :smiley:
Offline gribsymk3
« Reply #2 on: 09 November 2007, 18:14 »
Cheers mate, got any advice on the soundproofing
Offline Uruk Hai
« Reply #3 on: 09 November 2007, 18:59 »
Inside the doors behind the speaker pods and you could do the floor of the boot, realy the only limit is your time and money !
Offline Heyho
« Reply #4 on: 09 November 2007, 20:56 »
That's all fine kit you're using - the only thing I'd do is ditch the rear comps - you will save time, money and improve the sound.
Good luck with the install, and get some pics up when you're done.
Offline Guy
« Reply #5 on: 09 November 2007, 22:50 »
rainbows are a great choice... i have them in my mk3... you won't need components in the rear though... especially if you are running them through an amp... you will end up with a very high pitched little speaker in your ear and it will take over everything else... trust me... you won't need it. I have only components in the front and it is all you need.
good luck with the install... if you can upgrade to something a little more than the alpine sub.
Offline gribsymk3
« Reply #6 on: 10 November 2007, 16:34 »
do you really not think ill need the comps in the rear? will it still be as loud without??
whats wrong with the type R sub? can you recommend a better one
Offline Heyho
« Reply #7 on: 10 November 2007, 20:50 »
I promise you it WILL be loud enough with one set of comps.  Solid installation of the mids, and some good deadening is the way to go.
I've never heard an alpine type r, the box you put it in is what can really make the difference.
Offline gribsymk3
« Reply #8 on: 10 November 2007, 21:11 »
ive been told the best box for it is the alpine ported box, apparently its the proper box for that sub, what do i need to do for sound deadening, where do i need it? also do i just take off the door card and put it all in the door??
Offline monzablue16v
« Reply #9 on: 11 November 2007, 00:58 »
Alpine Type R subs aren't too cracking I had one for about 3 weeks and swapped it for a JBL as it just didn't seem loud enough (worked in a car audio shop) the JBL beat the Alpine into the ground it rocked like a mother.
