unlikely to work in all honesty;
1) incompatibilty between the ECU and immobiliser which means your car won't start
2) the differences between the 2 engines; the 150 runs at a higher boost and different mapping giving it the top end speed. not entirely sure on the internal differences between the 2 engines but its unlikely your 130 (if it starts!) will enjoy it much
3) 150 has front mounted intercooler so the air flow and the temperature could well make a significant difference
why did you need the ECU anyway? why didn't you just get it remapped?? or have you blown your existing ECU?
![huh :huh:](http://www.golfgtiforum.co.uk/Smileys/modern/huh.gif)
