Author Topic: Fusebox FAQ  (Read 200155 times)
Re: Fusebox FAQ
« Reply #10 on: 13 November 2006, 16:00 »
CE1 Fusebox Fuses & Relays:
Fuse No.DescriptionAmpere Rating
1Radiator cooling fan30
2Brake lights10
3Cigarette lighter, radio, dash clocks, interior lights, central locking15
4Hazard switch15
5Fuel pump (gasoline engines)15
6Open or fog lights10
7Rear lights, parking lights, side lights (left side)10
8Rear lights, parking lights, side lights (right side)10
9High beam, right, high beam indicator light10
10High beam, left10
11Windscreen wipers/washers15
12Heated seats, electric mirrors   15
13Heated rear screen15
14Heater blower, glove box light20
15Reverse lights, automatic transmission console light10
16Horn15
17Digifant ECU, 16v FEI module10
18Dual horn, coolant warning light control relay15
19Turn signals, brake warning light10
20Number plate lights10
21Headlights (Low beam, left)10
22Headlights (Low beam, right)10
Relay No.Description
1Open or Digifant relay
2Fuel pump (fuel injection) Glow plugs (diesel)
3Seat belt warning
4Shift light/MPG gauge relay (1985-1987)
5A/C relay
6Dual horns
7Open or front fog lights
8Load reduction/x-over relay
9Open
10Windscreen wiper
11Rear wiper
12Indicators, hazard switch
13Open or electric windows
14Cooling fan after-run (except 16-valve)
15Passive restraint (1988, 1989) or ABS/coolant temperature relay
16Idle speed boost control relay (k-jet 8v)
17A/C thermofuse or ABS
18Coolant warning light control relay
19Electric window relay
20Heated seats (left)
21Heated seats (right)
22Oxygen sensor system power supply (US cars w/CIS) / Automatic transmission relay
23Electric window thermofuse (30A)
24Glow plug fuse (Diesel-50A)
« Last Edit: 19 October 2010, 10:23 by rubjonny »
Re: Fusebox FAQ
« Reply #11 on: 13 November 2006, 16:01 »
CE2 Fusebox Fuses & Relays:
1Headlight, low beam, left10
2Headlight, low beam, right10
3Instrument panel lights, license plate lights10
4Glove compartment light, rear wiper15
5Wiper/washer15
6Fresh air blower, Air conditioning20
7Rear light, sidelight, right10
8Rear light, sidelight, left10
9Rear window defogger20
10Fog lights15
11Headlight, high beam, left, High beam indicator light10
12Headlight, high beam, right10
13Horn, Radiator cooling fan after run relay10
14Reverse lights, heated washer jets10
15Engine electronics, stabilizer valve, cold start valve10
16Instrument panel warning lights, MFA15
17Hazard switch, indicators10
18Fuel pump, oxygen sensor heater20
19Radiator cooling fan, air conditioning30
20Brake lights, cruise control10
21Interior lights, dash clocks, boot light, central locking15
22Radio, cigarette lighter10
1Air conditioning
2Rear Wiper
3ECU relay
4Load reduction/x-over relay
5Low coolant level control unit or Open
6Emergency flashers
7Headlight washers
8Intermittent wipers
9Seat belt/lights on warning relay
10Fog lights
11Horn
12Fuel pump (fuel injection) Glow plugs (diesel)
13Radiator cooling fan after run (except 16-valve) 2.0 16-valve: Starter interlock relay
14Automatic gearbox, coolant temperature indicator, starter interlock relay, Radiator cooling fan after run
15ABS pump relay
16ABS relay
17Heated seat control unit, driver
18Heated seat control unit, passenger, or Electric seat circuit breaker
19Automatic gearbox
20Open
21Electric window relay, ABS hydraulic pump fuse
22ABS valves fuse
23Air conditioning, power seat fuse
24Electric window fuse
« Last Edit: 19 October 2010, 10:28 by rubjonny »
Re: Fusebox FAQ
« Reply #12 on: 04 December 2006, 14:37 »
List of relay numbers, don't take this as gospel though, refer to the relay location guides above if possible!  Let me know if you know any more numbers or any below are incorrect:
1 = carb inlet manifold heater
2 = fuel pump (MK1 & Early MK2/Rocco K-Jet, no rev limiter)
5 = shift light and MPG gauge
17 = x-over relief (disables most ign live items while engine turning on starter motor)
18 = x-over relief (disables most ign live items while engine turning on starter motor)
19 = front wiper intermittant
20 = rear wiper non-intermittant (when you push the stalk forward, it'll only wipe once, no intermittant!)
21 = hazard/indicator
23 = switched relay, often used for electric windows
24 = switched relay, often used for horn or fogs on older models
30 = MK3 (GTI 8v or 16v?) ECU
31 = 'time control unit' fan control (fan after run)
32 = MK2 digifant ECU
33 = headlight washers
36 = headlights on warning (possibly seatbelt too?)
42 = coolant level sensor control (pre-90 & digifiz dash)
43 = coolant level sensor control (pre-90 & digifiz dash)
53 = misc equipment ignition switched (horn, fogs, leccy windows etc)
57 = k-jet 8v idle speed control relay
61 = decelleration cut-off for carb models
62 = fuel pump (Later MK2/Rocco/Cabby K-Jet, built in rev limiter)
67 = fuel pump (MK2 digifant, 16v and MK3 models)
72 = rear wiper intermittant
79 = ABS system relay
80 = fuel pump (MK2 digifant, 16v and MK3 models)
83 = control unit for syncro freewheel lock
90 = fuel pump after run control unit
99 = front wiper variable intermittant
103= glow plug
104= glow plug
109= early VR6 ECU relay
133= aircon
147= aircon
150= starter motor
167= fuel pump (MK2 digifant, 16v and MK3 models)
174= rear wiper
179= ABS control unit relay
191= hazard/indicator
192= intermittant wash/wipe for models w/rain sensor
204= 40a, fog lamp, electric fan etc. pinout compatible to 53
213= fan, assume radiator?
370= fan, assume radiator?
372= fuel pump relay, 97-05 Passat
389= intermittant wash/wipe
407= rear petrol flap
409= fuel pump relay, 02 Golf
644= x-over relief (disables most ign live items while engine turning on starter motor)
« Last Edit: 22 October 2010, 09:56 by rubjonny »
Offline mattkh
Re: Fusebox FAQ
« Reply #13 on: 23 April 2007, 13:56 »
Hi rubjonny
What a briliant effort.
How do I see what the locations A1 A2 B C D etc refer to. Is there a standard labelling system
Re: Fusebox FAQ
« Reply #14 on: 23 April 2007, 14:19 »
If you click the links on each post, it will take you to a picture of the rear of the fusebox, and will tell you where all the plugs are :)
Offline barkstar
Re: Fusebox FAQ
« Reply #15 on: 11 May 2007, 01:47 »
Position 12 on a CE2 fusebox is also the carb manifold heater thingy on Drivers and GLs etc - Relay is numbered 1, Part number 171 906 383. It is exactly same electrical spec as Digi fuel pump relay but the connector layout is a mirror image :angry: and just to totally confuse things the Digi relay is part number 191 906 383. Guess which relay was going like a set of castanets on my fusebox today?
Barkstar  :nerd:
Re: Fusebox FAQ
« Reply #16 on: 05 September 2007, 23:16 »
cheers dude, relay list updated!
Re: Fusebox FAQ
« Reply #17 on: 19 January 2008, 17:43 »
Early MK1/Scirocco Fusebox:
A
2  - blu/brn - spare wire, linked to D4 internally
3  - blu/grn - Jumpered to pin A5
4  - blu - Alternator pin D+
5  - blu/grn - Jumpered to pin A3
6  - blk/wht - Front left indicator
7  - brn - Horn(s)
8  - blk/grn - Jumper connector to: warm up valve, Aux air valve & fuel pump (from fuel pump relay pin L14)
9  - gry/blk - Left sidelight
11 - blk/yel - Horn(s)
14 - red/yel - Brake light switch
15 - blk - Reverse light switch
16 - red/blk - Brake light switch
17 - blk/grn - Reverse light switch
18 - wht/blk - Left headlight pin 56a
19 - yel/blk - Left headlight pin 56b
C
1  - blu/yel - Coolant temp switch - too cold
5  - brn - Windscreen wiper motor pin 31
6  - grn/blk - Windscreen wiper motor pin 53
7  - gry/red - Right sidelight
8  - yel - Right headlight pin 56b
9  - grn - Windscreen wiper motor pin 53e
11 - wht - Right headlight pin 56a
12 - blu/blk - Oil pressure switch
13 - blk/gry - Windscreen wiper motor pin 53a
15 - wht/lil - Series resistance for coil
16 - grn/yel - Windscreen wiper motor pin 53b
17 - grn/red - Windscreen washer motor
18 - blk/grn - Front right indicator
19 - blk? - Ignition Coil pin 1
D
1  - blu/red - Dash clocks plug T14/2 (Indicator warning light)
2  - blu - Dash clocks plug T14/10 (Battery warning light)
3  - Red - Headlight switch pin 30
5  - blk - Horn relay pin 86
7  - blk/wht - Headlight switch pin X
8  - blu/yel - Dash clocks plug T14/1 (Coolant temp guage - too cold)
9  - red/yel - Headlight flasher switch pin 30
10 - wht - flasher switch pin 56a
11 - brn - Earth
12 - wht - hazard switch pin 49
14 - red/gry - Dash clock, Cigarette lighter
15 - Red - Dash clocks plug T14/4 (Rev counter)
16 - wht/grn - Rear screen heater switch pin 86
17 - wht/blk - Headlight switch pin 56
18 - blu/blk - Dash clocks plug T14/11 (Oil pressure warning lamp)
19 - blk/red - Blower motor switch pin +
20 - blk/blu - Hazard switch pin 15
21 - red/wht - Hazard switch pin 30
22 - blu/wht - Dash clocks plug T14/3 (Main beam warning light)
E
1  - gry/blk - Headlight switch pin 58L
2  - blk - ignition switch pin 15
3  - blk/wht/grn - Hazard switch pin 49a
5  - gry/red - Headlight switch pin 58R
7  - grn/red - Jumpered to pin E20
8  - brn/blk - Wiper stalk pin J
9  - gry/grn - Headlight switch pin 58
10 - yel - Flasher switch pin 56b
11 - brn - Horn relay pin 87
12 - lil/blk - Dash clocks plug T14/8 (Fuel gauge)
13 - blk/yel - Heated rear screen switch pin +
15 - ? - Wiper stalk pin 53a
16 - grn/blk - Wiper stalk pin 53e
18 - grn - Wiper stalk pin 53
19 - blk/wht - Hazard switch pin L
20 - grn/red - Jumpered to pin E7, Wiper stalk pin T
21 - grn/yel - Wiper stalk pin 53b
22 - blk/grn - Hazard switch pin R
F
9  - gry/blk - Left rear light
10 - wht - heated rear screen
12 - lil/blk - Fuel guage sender
13 - gry/grn - Number plate lights
14 - red/grn - Interior light
15 - gry/red - Right rear light
16 - blk/grn - Rear right indicator
18 - blk - Reverse lights
19 - blk/wht - Rear left indicator
20 - blk/red - Brake lights
G
1  - red - jumpered to pin H
6  - red/blk - Radiator fan thermo switch
7  - blk/gry - Rear wiper relay pin 53a, rear wiper motor pin 53a
H  - Red - Battery +ve, ignition switch pin 30, jumpered to pin G1
« Last Edit: 30 July 2010, 09:35 by rubjonny »
Offline uber pikey
Re: Fusebox FAQ
« Reply #18 on: 22 May 2008, 04:31 »
I purchased my car three weeks ago and all I can say is thanks to rubjonny as this little lot has saved me hours of head scratching, thanks. :smug:
I saw it so I took it.
Offline Roverdose
  • So long and thanks for all the fish!
Re: Fusebox FAQ
« Reply #19 on: 04 August 2008, 11:50 »
rubjonny, i love you, you just saved me alot of cash! ALOT of cash! Your my new favorate person! legend!
