Author Topic: Roof mounted aerial  (Read 1361 times)
Offline dodfus
Roof mounted aerial
« on: 30 June 2006, 13:17 »
Hello,
I have noticed that the reception I get has dropped off remarkably and on looking at the aerial I notice that the seal around the base of it to the roof has split.  Could this be the cause and also does this then allow water to ingress into the car roof?  How easy is it to fix this?  Can you get at all the bits externally or not?  Is there some sort of amplifier included in the aerial base?
Sorry for all the questions
Offline The Doc
  • E63s Estate - Vito Sport
Re: Roof mounted aerial
« Reply #1 on: 30 June 2006, 17:39 »
The ariel has an amplifier yes, but it is in-line not in the base!
They allways go wrong so try that first!
Offline dodfus
« Reply #2 on: 03 July 2006, 10:35 »
Thanks for the reply.  Presumably this amplifier is behind the radio somewhere?  Is it just a case of pulling the radio out and fitting a new one?  Is it possible to get an upgraded amp so that the signal strength is greater?  On the aerial end, is it possible to fit a new sleeve around the base unit so that no water can get in?
Thanks
Offline paulm007
  • On my orders, release Hell
« Reply #3 on: 03 July 2006, 13:23 »
Not sure how old your car is Dodfus but I had the same problem with my aerial.  VW changed it under warranty and reception is much better, the VW guy said they are always failing!
53 GT TDI 130 - Sold
07 GTI Ed30, 3dr, Black pearl now sold! :(
Offline dodfus
« Reply #4 on: 03 July 2006, 13:52 »
Unfortunately, it is quite old so no longer under warrenty - a diy job I'm afraid.
Offline The Doc
« Reply #5 on: 03 July 2006, 15:28 »
Its not behind the radio - I think (may b wrong) its in the headlining in the rear!
