Author Topic: ETKA part numbers - Post queries here - Often trimmed down  (Read 199525 times)
Offline Agreeable Slick
  • Unit
Right just been perusing the mk2 section and a lot of people ask for part numbers. So here is my thought, everyone put their request in here for part numbers (for mk2s - pm the model mods in other sections if you want a similar idea in the mk1,3,4,5 sections) and whoever can help put the part number and item description in reply. Then once a week i will come and tidy it all up so we have a comprehensive list of part numbers for commonly asked for parts, in a nice tidy thread.
cheers
« Last Edit: 15 February 2010, 18:20 by Agreeable Slick »
  • Unit
Re: ETKA part numbers - (just a trial at the mo)
« Reply #1 on: 06 February 2006, 13:08 »
I.E.
191 998 135 A - 1 set of mounting parts for the spot lights from VAG.
056 919 081 E - Oil Pressure Switch (1.8 BAR 1 pin White)
068 919 081    - Oil Pressure Switch (1.4 BAR 1 pin Black)
068 919 081 A - Oil Pressure Switch (0.9 BAR 1 Pin Grey)
Etc... posts will be deleted once they have been answered and listed/described. SO REMEMBER TO CHECK BACK HERE IF YOU ASKED SOMETHING.
  • Unit
« Reply #2 on: 06 February 2006, 13:44 »
- Organisys
321 601 025 H - G60 Steel Wheel
871 601 171    - Black Wheel Cap ( 142mm Diameter)
321 601 171 C  -  Wheel Cap
Offline jimbo
« Reply #3 on: 08 February 2006, 00:02 »
lift pump for a digi = 191 906 092 AD
« Last Edit: 08 February 2006, 16:18 by The Slick Effect... »
aye up me duck!
Offline Rain
  • forum irregular
« Reply #4 on: 08 February 2006, 14:23 »
lift pump for a digi = b 191 906 092 AD
just a correction if someone can mod jimbo's got a lift pump this morning
K-Jet & Digifant Lift pump  <89                 191 906 092 AD
Digifant In Tank Lift pump    89>               357 906 092 C
« Last Edit: 08 February 2006, 14:28 by Rain »
  • Unit
« Reply #5 on: 09 February 2006, 16:25 »
171 919 379 A - Temp Sensor - 2 Pin
049 919 501    - Temp Sender - 1 Pin Black ( diesel & Turbo Diesel )
049 919 501    - Temp Sender - 1 Pin Black ( 16v - There are about 4-5 in the engine)
026 906 161    - Temp Sensor - 2 Pin White ( Mono Jetr)
« Reply #6 on: 10 February 2006, 09:47 »
Just a few more part #s for various temp sensors :)
171 919 379 A - outside air temp sensor for MFA - £17.64
025 906 041 A - Digifant 'blue temp sensor' for ECU - 2 pin, blue - £9.68
251 919 501 D - temp sensor for dash gauge - 2 pin, black - £17.64  :shocked:
049 919 563 A - oil temp sensor for MFA - 1pin, white - £12.19
035 919 561 A - oil pressure sensor for VDO gauges 0-5/1.8 bar - 2pin, black - £59.07
Prices do not include VAT :)
  • Unit
« Reply #7 on: 12 February 2006, 17:20 »
Stan:
191 853 042 - Trim Foil for Rear Hatch
+ 701 853 585 - Body clips
357 853 586 D - Grommets
171 877 651 = Wind Deflector
443 877 681 D is the hinged arm left
443 877 682 D is the hinged arm right
« Reply #8 on: 07 March 2006, 09:38 »
For Gambit:
026 133 551 - 16v injector, coarse thread - £30 (looking at it, this includes the top & bottom seal)
034 133 557 E - 16v injector top seal 6x5.2 - £2.02
035 133 557 A - 16v injector bottom seal, bottom of metal 'top hat' 9.8x1.4 - £1.88
034 133 555 A - 16v threaded upper insert - £3.19
035 133 554 - 16v lower plastic insert - £1.41
035 133 557 - 16v lower insert seal 16.5x19.5x1.5 - £0.87
Pegasus is correct:
321 601 025 H - 6J x 14 ET38 - Manhattan, Madison - £34.48
357 601 025 M - 6J x 15 ET35 - Redline, Blackline, Golf G60 - £33.66
« Last Edit: 31 July 2007, 23:18 by rubjonny »
« Reply #9 on: 07 March 2006, 22:34 »
Some other random bits, as always VAT is not included:
1H0 711 183 - MK3 weighted shift rod - £11.01
3B0 955 531 - MK3 variable intermittant wiper relay - £26.99
161 711 141 D  1BX - MK2 G60/Rallye/16v Proper leather gear knob - £19.98
191 798 116 A - gear lever ball/housing repair kit - £11.20
