Need help people - going mad today on this....!!!
Right my black mk1 golf cab (1992) which has had a lot of work done to it over the last 3 weeks including having the engine taken out and put back in today
![Smiley :)](http://www.golfgtiforum.co.uk/Smileys/modern/smiley.gif)
isn't starting up properly! It fires up for a second and dies and then just turns over for ages then fire up for a second and then turns over - until battery dies!!!
I've checked the following.
1. There is fuel in the tank
2. Fuel pump is pumping fuel to the Fuel filter at engine area so we have pressure building up as it should be.
3. Fuel is going into the CIS unit.
4. Fuel is going into the warm up regulator (front of engine) one connection
5. Seems no fuel is coming out of the regulator (front of engine) second connection
![Sad :(](http://www.golfgtiforum.co.uk/Smileys/modern/sad.gif)
6.There seems to be no fuel going from CIS unit to the injectors in the head unit - as taken out spark plugs and they are bone dry and no fuel is on the top of the pistons when turning over car, with the sparks plugs taken out and a light down holes to see if petrol is there.
So what I need to understand is from people - is there a detailed site or discussion or does someone knows, more on the mk1 CIS fueling process so I can understand how the fueling is passing - so I can figure out what the issue is.
thanks Si.
