Author Topic: Mk 8.5 operating system/screen gemlins??  (Read 1636 times)
Offline CarbonGTD
« on: 06 February 2025, 09:23 »
I have had my new Mk 8.5 for 10 days - until this morning, all good.  This morning (cold 2 deg start) 3 times on my commute in to work the car 'lost' all settings as I drove along - so the instrument binnacle reverted back to 'factory' setting (not my chosen nav view) the tone controls for the audio reverted back to their 'flat eq' setting etc etc ie like some sort of system re-set.  Each time I reverted everything back to how it should be, only for the 'factory re-set' to happen again (as I was driving along) a few minutes later.  Really annoying.  Nothing like that happened in 4 yrs of owning my Mk 7.5 GTI PP.  Has anyone else had a gremlin like this in their Mk 8.5 so far??
Offline WelshGolf
Re: Mk 8.5 operating system/screen gemlins??
« Reply #1 on: 06 February 2025, 12:57 »
Had mine for 4 months now and not had any problems like that. Id does make a 'bong' on start up though and I can't understand what the bong is for, no errors anywhere.
Golf 7R - Gone
Golf 7.5 GTi - Gone
Golf 8 Clubsport - Gone
Golf 8.5 Clubsport - Here
Offline joet
« Reply #2 on: 06 February 2025, 16:08 »
I've had mine for almost four months as well and not a single bong or warning. Been rock solid which is a blessed relief after the Mark 8 I had. Fingers crossed
Offline fredgroves
« Reply #3 on: 06 February 2025, 19:50 »
Carbon... Did the infotainment reboot? If so did you hear a double click sound?
Offline Carlosfandango
« Reply #4 on: 06 February 2025, 23:52 »
Has it done it since the time you mention? Have you tried a soft reset of the infotainment by continuously pressing the power button for 10-15 seconds until it restarts?
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline sipj
« Reply #5 on: 07 February 2025, 08:55 »
Mine has all been good overall, with only a small issue changing the volume when using Carplay.
Current: Golf GTI 8.5. Pure white/black, pan roof, Queenstown, DCC, HK, Area view, spare wheel
Gone: 2018 Golf GTI 7.5 performance pack with standard spec
Gone: 2016 Golf GTE 7
Gone: 2013 Audi A3 S-Line
Gone: 2010 Golf GT TDI
Offline WLT
« Reply #6 on: 07 February 2025, 20:55 »
I had similar behaviours, dealer advised me to choose me as a primary user on the start-up, as without that the car is booting into the guest mode. I have no such issues since.;)
Current: Red 8.5 GTI
Past: Audi A4 45tfsi, Audi A4 35tdi, Golf 8 GTI, Golf 7…
« Reply #7 on: 07 February 2025, 22:17 »
Ah yes! Now you mention this, it reminds me I had the same when I was unable to register as primary user when I first got the car, the dealer deleted my old car incorrectly which meant I couldn’t then use the current email as the log in for the new car, I had to register for MyVolkswagen again using a new account, all was well after that. However, the OP states that it is resetting in between ignition cycles which sounds different.
« Last Edit: 07 February 2025, 22:20 by Carlosfandango »
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
