Evening all,
I'm going to view a Mk7 on a 65 plate, on Tuesday at a dealer, in Hook. Noble motorsports, if anyone knows them.
Anyway, I've zoomed in as much as I can on the car images, and it appears the headlights, may have been split at some point.
The casing looks poorly repaired, but hopefully moisture and water is kept out.
Now, could this be a nightmare to repair, if it's found to be true and then becomes a haggling zone?
I'm pretty good with most things, though never split headlights before, and seeing 2nd hand sets going for £600 and more online, is stiff to swallow, if everything else, is going for it.
A couple of alloys have the beginnings of corrosion, and would need a repair...assuming diamond cut?
Anyway, if anyone knows the car WV65YRN, I'd be eager to know more about it, before I drive from Essex Tuesday morning.
Wayne.
