Author Topic: Heater Problems  (Read 4175 times)
Offline Jake1
Heater Problems
« on: 02 January 2025, 21:53 »
Hi all,
Wondering if some one can help,
I’ve got 2015 GTI however doesn’t seem to be getting hot enough when the heaters are on full,
I’ve checked the Heater Core / Matrix pipes and both return and inlet are boiling hot. I’ve check the heater flap motor and it’s moving as it should & calibrated it via the controls. The car seems to get hotter when I have the fan speeds set lower / say set to 4. So the heat isn’t as hot when the blowers are on full.
Monitored via obd and coolant temperature is 212 degrees
Could it be a thermostat or heater control valve?
Thanks
Offline Big Col
Re: Heater Problems
« Reply #1 on: 03 January 2025, 18:27 »
more likely the matrix is starting to block up - its a common problem on the platform.
Current - 2019 Golf GTI
Previous, 2016 Golf GTD, 2014 Leon FR, 2010 Ibiza FR, 2006 Fabia vRS , various Vauxhalls
Offline Finglonga
Re: Heater Problems
« Reply #2 on: 04 January 2025, 10:52 »
Yep, as said  sounds like the Matrix, mine was the same I also needed to have the Aux  Heater pump replaced as it was not working. The matrix was clogged up and you can not flush them as they have a bypass.
Online Adam T7
Re: Heater Problems
« Reply #3 on: 04 January 2025, 12:04 »
A bit late unfortunately but it pays to remove the silicate bag from the expansion tank☹️
