Author Topic: Problem with Parking Sensor After Retrofit Installation  (Read 2180 times)
Offline josh.shamir
Hello,
I had the following "retrofit" components installed on my Volksvagen 7:
• 21981-1  VW Navigation Retrofit - Radio Composition Media 8" to Navigation Discover Media MIB2.5 display 8"
• 45034  DAB, DAB+ antenna module - Retrofit kit - VW Golf 7
• Rear Assist - Rear camera - Retrofit kit - VW Golf 7
The components work, but when I press the "Park Assist" button, whether the monitor is on or off, the screen relating to the parking sensors does not appear on the monitor; only the sound of these sensors is played. Instead, the screen relating to these sensors can be selected from the screen when I activate the rear camera, which is activated only when I set the reverse gear. So, I think that the sensors work correctly, but there are problems in their invocation (priority, encoding?).
I have attached the result of the diagnostic scan performed via VCDS for completeness.
Thanks in advance to anyone who tries to help me.
Code: [Select]
Thursday,17,October,2024,07:55:19:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: xxx   License Plate:
Mileage: 97610km-60652mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F 6C
VIN: xxx   Mileage: 97610km-60652miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
Address 01: Engine (J623-CXXB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 CL    HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 6336
   Revision: 22004001
   Coding: 0111401243241D092000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM16TDI03004L906056CL 004011
   ROD: EV_ECM16TDI03004L906056_004_VW37.rod
   VCID: 79F958E3F8D95B5B8C-802C
   VINID: 9E69EAAAA465A979C30C30490078C96522
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 91196000007232
   Coding: 01FA62A12423096F0778060941C32580462490E06082A4F300400078C002
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
   ROD: EV_Brake1UDSContiMK100IPB_034.rod
   VCID: 7EF34BFFE1F77C63B9-802A
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
   Component: Climatronic   H03 1001
   Revision: 00001K08    Dataset Number: 0000
   Coding: 00020104202100011005000000101002
   ASAM Dataset: EV_ACClimaBHBVW37X 004131
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 69D908A38879EBDB7C-803C
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 CJ    HW: 5Q0 937 084 AL
   Component: BCM MQBAB M   H24 0175
   Serial number: 01061613102527 Dataset Number: V03935237LD 0001
   Coding: 00000842C24100DB4BE44000000403081000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 015001
   ROD: EV_BCMBOSCH_015.rod
   VCID: 020B3F0F950F1883DD-8056
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    160419  043 0551
   Serial number:         160430062508
   Coding: 0E4DDD
   Humidity sensor: interior:
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Component: G355_FeuchteS  H07 0002
   Serial number: 71487568
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 K    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0054
   Revision: --------    Serial number: 39331613300867 Dataset Number: V03935236FM 0001
   Coding: 0031151001
   ASAM Dataset: EV_EPHVA18AU3700000 002026
   ROD: EV_EPHVA18AU3700000_002_VW37.rod
   VCID: 4385FA0BCA95D18B96-8016
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Component: AirbagVW20    015 0388
   Serial number: 003F6R1R2858 Dataset Number: V03935211YZ 0001
   Coding: 98CCC000000000005C0000CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 4189F003D089C39B84-8014
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 001 205 16
   Component: SideSensor_Df  001 0887
   Serial number: 35767000000D45242B1R
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 480 001 205 16
   Component: SideSensor_Pf  001 0887
   Serial number: 35867000000970206B1M
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 480 400 605 16
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502C32057285424X
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 480 400 605 16
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502C52057284D2A7
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 400 205 16
   Component: FrontSensor_D  001 6149
   Serial number: 3556502B32057281C04
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 07051608490079
   Coding: 0400
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_020_VW37.rod
   VCID: 0D111C33DC5157FBB0-8058
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 741 A    HW: 5G1 920 741 A
   Component: KOMBI         208 7653
   Coding: 07A41A002380000801082A001400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009005
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 2541449324E10FBB98-8070
1 Fault Found:
9456433 - Key
          B104B 31 [008] - No Signal
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 247
                    Date: 2000.00.00
                    Time: 00:00:00
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AH    HW: 5Q0 907 530 E
   Component: GW MQB Mid    127 1244
   Revision: --------    Serial number: 0004866905 Dataset Number: V03935232TG 0001
   Coding: 030100041F087300FB000248080F00010001050000000000000000000000
   GVL: 01543C0000000000400C00000002480000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 013020
   ROD: EV_GatewLear_013.rod
   VCID: 77FD5EDBCECD4D2BFA-8022
   Generator:
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29160000875620076174
   Coding: 28FFFF
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Component: J367-BDMHella  H04 8050
   Serial number: 6132530204
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Component: TSG FS        020 0041
   Serial number: 010516EE105741 Dataset Number: 5G0222v____ 0068
   Coding: 003003208000040000001000
   ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000009872734
   Coding: 110000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Dataset Number: V03935226XC 0001
   Coding: 0103
   ASAM Dataset: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB_012_VW37.rod
   VCID: 4487F917CF9BD6B3AF-8010
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 020416ECL11343 Dataset Number: 5G0157v____ 0064
   Coding: 003001208E00040000801000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 428BFF0FD58FD8839D-8016
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000009931783
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    H41 0480
   Serial number: VWZAZ2T1550911 Dataset Number: 5G0CV1v____ 8336
   Coding: 02730001FF0000005111010100880A001F0100C401A00100CF
   Shop #: WSC 17873 123 50804
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 326BAFCF652F68030D-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHW0152369
   Data carrier:
   Subsystem 2 - Part No SW: 5NA 919 866 ET    HW: -----------
   Component: ECE AS 24/25  --- 2210
   Serial number: --------------------
4 Faults Found:
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 206
                    Mileage: 97591 km
                    Date: 2024.10.09
                    Time: 18:53:14
                    Voltage terminal 30: 12.0 V
                    System_Software_Error-SW_Status_Consistency: 04 01 01
                    System_Software_Error-SW_Status_Device: o
2562 - Navigation System
          B126C F0 [009] - Navigation Database Faulty
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 206
                    Mileage: 97591 km
                    Date: 2024.10.09
                    Time: 18:53:14
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 206
                    Mileage: 97591 km
                    Date: 2024.10.09
                    Time: 18:33:48
                    Voltage terminal 30: 11.8 V
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
2565 - GPS Antenna
          B1054 13 [009] - Open Circuit
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 206
                    Mileage: 97591 km
                    Date: 2024.10.09
                    Time: 18:33:48
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Dataset Number: V03935314JY 0001
   Coding: 0184020142002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
   VCID: 397998E3B8599B5BCC-806C
2 Faults Found:
10489856 - No Basic Setting
          B2010 00 [009] - -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 206
                    Mileage: 97591 km
                    Date: 2024.10.09
                    Time: 18:42:36
                    passive
13705478 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 206
                    Mileage: 97591 km
                    Date: 2024.10.09
                    Time: 18:42:37
                    passive
End-------------------------(Elapsed Time: 03:54)--------------------------
