Author Topic: Mk5 golf help needed please  (Read 3649 times)
Offline B3NJY
« on: 08 July 2024, 07:21 »
Anybody had same issue and resolved ?
I have a 08 mk5 golf gt sport tdi 140.
Owned this car for 5 yrs hassle free.
Last month as I was driving car it just cut out and rolled to a stop, I tried starting and just cranked over and over and wouldn’t start.
I called out the trustworthy AA and fuel pump was checked and then told me it was timing. Towed to garage and was told by mechanic timing was spot on and was crank sensor.      It’s been running fine then same thing happened today.    Just cut out and rolled to stop.
Turns over and will not fire up ??    I’ve checked fuses and all good 🤬🤔🤔🤔🤔
Offline Nino
  • MK6 GTi Edition 35 - Candy White
Re: Mk5 golf help needed please
« Reply #1 on: 08 July 2024, 09:14 »
I think your Garage has already given you the answer and it does sound like it could be from your discription but its hard to tell these things over the internet :)
The crank sensor's role is managing ignition timing and fuel injection which is crucial, and when these processes are disrupted, it can lead to inefficient combustion and stress on various engine parts. Poor performance. A car with a bad sensor might experience rough idling, prolonged cranking, or may not start at all.
VW Car history
Mk3 1.8 GL - Silver - 5 door
Mk4 1.8t - Silver - 3 door
Mk4 R32 - Black - 5 door
Mk5 GTi - Black - 5 door
Mk4 R32 - Deep Pearl Blue - 3 door
MK6 2.0 TDI - Graphite Blue - 5 door
MK7 GTD - Solid Black - 5 door
MK6 GTi Edition 35 - Candy White - 3 door
Offline B3NJY
« Reply #2 on: 08 July 2024, 11:28 »
Crank sensor was changed and timing looked at by garage which is spot on but it’s done the same again after a couple of weeks.
Offline Nino
« Reply #3 on: 08 July 2024, 11:47 »
You often find these things happen when 3rd party (euro car parts) parts are used.
In my experience, when it comes to sensors and such, only use OEM.
Would be worth double checking if this was the case, if OEM parts were used, then I would start looking at the loom to it.
VW Car history
Offline B3NJY
« Reply #4 on: 09 July 2024, 21:13 »
Bought a Bosch one and fitted today.    Still no good.    :sad:
Offline jv
  • Administrator
« Reply #5 on: 10 July 2024, 20:12 »
Checked for fault codes?
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline barrym381
« Reply #6 on: 26 August 2024, 13:11 »
Fuel pump relay is my guess
