Beat me to it Gnasher.
I've just managed to obtain the self study manual for the engine and it's very interesting. With regards the fuelling system, it says this (for anyone who's interested) ?
The new TSI engines of 2.0 l have a double injection system. This means that the conditioning of the mixture can be done in two different ways. One of them is injected directly into the cylinder with the IST high-pressure injection system and the other to use as injection system multipoint injection (SRE).
Operating ModesThe control concept for executing the operation modes has been standardized using a mapping. The mapping determines if and when the engine
can be operated SRE mode and when it can operate in high pressure mode. It distinguishes between the following operating modes:
- Single injection SRE
- single high-pressure injection
- Double high-pressure injection
- Triple high-pressure injection
The engine switches between different operating modes depending on the temperature, the load and the engine speed.
Starting the engineIn cold engine and a temperature of the coolant below 45 ° C and at each engine start, a triple direct injection takes place during the compression stroke through the high pressure injection system.
temperature and catalyst heating climbDuring this phase, a double direct injection takes place during the intake and compression time. The ignition point is shifted slightly towards the "delay". intake manifold flaps are closed.
Engine operating in partial load rangeWhen the engine temperature exceeds 45 ° C and the engine operates in the partial load range, there SRE switching mode. Intake manifold flaps remain largely closed.
Motor operating in full load rangeBecause of the high power requirement, the system returns to high pressure mode. A double direct injection takes place during the intake and compression time.
degraded mode operationIn case of failure of one of the two injection systems, the engine is driven only with the remaining system by the engine computer. The vehicle thus remains operational. The red light engine in the instrument cluster lights up.
