Quote from: Wide on 02 June 2017, 09:09Quote from: andy28 on 30 May 2017, 23:08Excellent news, I'll let you know when I'm coming to Sweden to collect my beer ;-)I've not tried anything with start-stop but will have a look to see what I can find.No time yet?. Someone else? I H**te the Start/stop.. Is it the long coding you want?Disable stop/start 1) Select Control unit 192) Select Adaptation3) Select Stop start limit voltage4) Change value to 12 (default is 7.4)5) Press the green tick to confirm
Quote from: Booth11 on 02 June 2017, 09:29Quote from: Wide on 02 June 2017, 09:09Quote from: andy28 on 30 May 2017, 23:08Excellent news, I'll let you know when I'm coming to Sweden to collect my beer ;-)I've not tried anything with start-stop but will have a look to see what I can find.No time yet?. Someone else? I H**te the Start/stop.. Is it the long coding you want?Disable stop/start 1) Select Control unit 192) Select Adaptation3) Select Stop start limit voltage4) Change value to 12 (default is 7.4)5) Press the green tick to confirmGreat!, will test this tonight!
Quote from: Wide on 02 June 2017, 09:42Quote from: Booth11 on 02 June 2017, 09:29Quote from: Wide on 02 June 2017, 09:09Quote from: andy28 on 30 May 2017, 23:08Excellent news, I'll let you know when I'm coming to Sweden to collect my beer ;-)I've not tried anything with start-stop but will have a look to see what I can find.No time yet?. Someone else? I H**te the Start/stop.. Is it the long coding you want?Disable stop/start 1) Select Control unit 192) Select Adaptation3) Select Stop start limit voltage4) Change value to 12 (default is 7.4)5) Press the green tick to confirmGreat!, will test this tonight! I've linked this before, as well as the obdeleven pro forum, there's lots of coding here, where we created an obdeleven board.. http://www.vwroc.com/forums/forum/84-obdeleven/Any thread with "coding" in the title is the long coding.
