Author Topic: How to: Make rose-jointed adjustable drop links  (Read 19211 times)
Offline dom
  • Back in a Mk4
« on: 29 April 2014, 20:58 »
Wazzzer came up with a solution for a set of adjustable drop links which include a ball joint and a rose joint to allow them to sit at a better angle than standard links, especially if running a TT/S3/LCR arb that goes under the driveshaft.
This is what you will be buying:
And this is what you will be making:
For one pair of drop links you need:
2 of these: http://www.ebay.co.uk/itm/320997544140?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
2 of these in LH thread to match the above: http://www.ebay.co.uk/itm/191085094424?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
2 of these: http://www.ebay.co.uk/itm/380444144576?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
and one pack of these: http://www.ebay.co.uk/itm/280505700707?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Total is £44ish
The rubber boot goes over the rose joint, which then screws to the ball joint. The misalignment spacers go outside the rubber boot, with the smallest face against the rose joint to allow for maximum movement.
When they are fitted they look like this (S3 arb pictured):
The only slightly fiddly bit is getting the rubber boot over the rose joint, I used this guide to help:
http://www.planetmx5.com/forum/viewtopic.php?t=2460
Offline XMC1980
  • Don't piss in my pocket and tell me it's raining!
Re: How to: Make rose-jointed adjustable drop links
« Reply #1 on: 03 May 2014, 23:17 »
The misalignment spacers..... I'm confused as it says smallest face against the rose? Forgive me if I'm being a tit but they're the same size both sides?
Mk4 1.8T 218ps AUQ
Head and turbo rebuild, jom coilovers, s200 induction, forge 007, anniversary body kit, 18" RS4 reps, Rtech remap stage1, turbo back stainless and miltek cat back
Offline dom
  • Back in a Mk4
« Reply #2 on: 05 May 2014, 09:51 »
The face pointing upwards in the first picture is smaller.
Offline XMC1980
« Reply #3 on: 07 May 2014, 01:38 »
Dom forgive me, but I'm still trying to work out how these spacers go? How can I rebuild the engine and not work this one out! I wish I wasn't spanish sometimes.......
Mk4 1.8T 218ps AUQ
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 07 May 2014, 20:43 »
They're conical shaped, as in the pic the surface not on the table goes against the rose bush. It gives them more range of movement
Offline XMC1980
« Reply #5 on: 07 May 2014, 21:02 »
Ok I get it now! I guess it just seems more natural to put them the other way round :) thanks guys
Mk4 1.8T 218ps AUQ
Offline spudboy6
  • Just like a golf ......
« Reply #6 on: 06 September 2015, 23:22 »
Some of these parts are no longer on eBay, I fitted the above parts to the letter and after 6 months the joints had play in , looking to buy more I realised the ball joints are out of stock and have been for some time so looked for an alternative ,
Just ordered from mc Gill Motorsport their best joints made from Kevlar for similar money
Here's my shopping list and free postage
Will let you know how they feel once delivered
