Ok like always it's been a while but a lot has been done in that time.
First of all ordered a 3 inch exhaust and got that put on. Also ordered a relentless 3 inch downpipe which I was told would fit by them but didn't ended up having to cut it apart and make a custom downpipe. Will upload videos of it when I can figure out how to from an iPhone. Performance wise big difference, absolutely love the sound of it too.
Then the usual MOT time came round, replaced the rear shocks as they were dead, I plan on changing the entire suspension unit in the near foreseeable future so this is just temporary. Was pretty ok to do at home.
Changed two front tyres, and managed to squeeze it through MOT.
A mod I have been wanting to do was do the dogbone mount bush as I did have a bit of play with engine movement, so changed that to the softer red bush for now. May change it again later was put off by the amount of people saying it vibrates a lot.
Looking at this picture I definitely will be putting in the stiffer bush and also changing the small bush as I didn't do it at the time. Muppet.
Gear changes were tighter, and it really did help put the power down.
I managed to get my hands on a vag com copy which said I had a coolant temp sensor fault code and fuel pump relay so swapped those out same day.
So all was good until I started getting throttle cut on full throttle my vag com is basically rubbish so I was unable to log it and see what was actually happening but I figured try upgrading the fuel pump and see what happens, went for the A35HV from badger5. It seemed straight forward but was very annoying, getting the old c clips of the fuel lines. Then the lines themself, use a blade makes it much easier.
Back it went in the fuel tank and away went my throttle cut. Temporarily, I think it may be down to injectors, I also did scan it again and find a maf intermittent and o2 sensor fault, will be changing those soon to see if it helps. If anyone has any ideas or could help me log the issue please do give me a shout!
I then had a wheel bearing go on me and changed it, by far the most annoying job I've done on the car as I didn't have the right puller tools so took the axle stub off with the inner race on it to JNL racing where he very kindly managed to get it off. No pictures were taken as I just wanted to get it done with. A week later same side opposite bearing has begun making noise and will change that as soon as it's too loud to bare. Did this in a rush in order to get down to Santa Pod for GTi festival, didn't drag but went down with few friends which one of which did. Great day, lots of nice cars.
For a while now I've had a temperature problem concerning my thermostat hot days would rise, heaters on would drop significantly so I got a 74 degree thermostat off eBay and swapped it round. Very small space to work in. But is possible to do with alternator in place.
Old thermostat
Nice new one.
Old one completely destroyed by the looks of it?
And that went back into the car with a nice new O ring, since then went down to Audi driver and decided to take it on the Castle Combe track. One and a half laps in my boost pipe popped off which didn't entirely ruin the day but identified a weakness in the car, only blew off because that pipe was cut down all other pipes are beaded just need to properly bead that.
Lots planned for the future as an s3 with 3 inch exhaust and revo intake and r32 mk5 are my rivals, feel like the underdog as they both have 4 wheel drive system. Thinking of rods...
Thanks for reading guys
