Author Topic: Changing GTI gearbox oil  (Read 4686 times)
Offline John W
« on: 02 October 2013, 16:58 »
Guys
I have done a search, but can't find an answer...
The gearbox in my Son's 8V GTI is very noisy in reverse and notchy into second when cold. I know it won't cure this, but I want to change the gearbox oil to see if it helps.
Questions- what spec oil do I need, and whats the best way to find and get at the filler and drain plugs?
Thanks !
Kind regards
John
1997 VW Golf GTI 8V 5 door
1979 Porsche 924 Lux
1982 Porsche 924 Lux Auto
1986 Porsche 944 Lux
1996 BMW 525iX SE Touring (4x4)
Offline itavaltalainen
Re: Changing GTI gearbox oil
« Reply #1 on: 02 October 2013, 19:20 »
You need about 2l of 75w90 - I would recommend synthetic oil, personally I have used Total Transmission Syn FE 75W90. Paid about 20£ for 2 litres.
For the drain and fill plugs you need a 17mm allen key.
Tip: First try to undo the fill bolt - if you can't get this open then you still have oil in your box if you can't get it open and have not drained the oil already!
The drain plug is on the bottom of the gearbox, see here,
 the fill hole is on the side of the box (take left wheel off for access); it's the one being undone in the photo below.
Changing is simple, undo fill plug, undo drain plug (have container under it), wait for it to drain, use a short piece of garden hose and a funnel of suitable size, pour approx 100ml down with drain plug still undone to flush a little bit. Do up drain plug, now fill it up again until it comes out of the fill hole.
Remember that this crap is fairly viscous, so pour slowly! You can heat the oil up before pouring it in.
Then do up fill screw, job done.
Made a huge difference on mine, basically feels like a new box (not that it had anything wrong with it apart from stiff gear changes).
PS: Take a shower afterwards - fraeking gear oil stinks of piss  :sick:
« Last Edit: 02 October 2013, 21:54 by itavaltalainen »
Offline John W
« Reply #2 on: 03 October 2013, 17:00 »
Thanks very much-a very comprehensive answer!  :smiley:
Kind regards
John
