Author Topic: mk1 cabriolet overheating  (Read 11014 times)
Offline dubpirate
« on: 14 September 2013, 19:34 »
ok so its fine when driving needle sits below were it should infact nearly all the way to the left
stationary it overheats the fan dosnt kick in
i have fitted a switch to the fan and i started the car let it get warm enough to start reading on the guage and then even with the fan on constant the tempersture still rose slowly i mean very slowly but i didnt let it get to half way as last time it did it boiled over
any ideas
my temo light doesnt work at all
Offline dubpirate
Re: mk1 cabriolet overheating
« Reply #1 on: 15 September 2013, 19:03 »
ok update
i run it today for an hour drive then stopped on my drive with engine running and fan on the fan will keep it from overheating
so next i need to find out why the fan isnt kicking in
am i correct with thermostat ? and which sensor controls this thanks
Offline chalky white
« Reply #2 on: 15 September 2013, 19:04 »
drain the system completely and flush it out, getting rid of any muck in there.
Make sure belt to water pump is not slack.
Take the thermostat out and drop it into a bowl of boiling water to see if it operates, if not a new one. For the cost I'd put a new one in anyway.
When you refilled, run the engine and squeeze the rad hoses to get all the air out with the cap off. Make sure you have the blue rated expansion tank cap too. Remember to re check level and refit cap.
No temp light can be a poor connection on the clocks, so putting a couple of turns of leccy tape around the stub where the blue foil fits over helps with better contact. In fact it helps with a lot of clock faults inc flashing temp light etc etc.
Also clean the copper contacts carefully too.
There are 2 sensors that operate the light one in the expansion tank for low level fluid  warning plus one on the coolant flange to show over heating.
I put a new red spade connector on the wire and a new sensor in from GSF about a fiver???
« Reply #3 on: 15 September 2013, 19:05 »
iirc the sensor is at the bottom of the Rad.
« Reply #4 on: 15 September 2013, 19:14 »
Just seen your on MK1OC so plenty of MK1 Q&A'S on there.
Offline dubpirate
« Reply #5 on: 15 September 2013, 20:46 »
hi thanks for the reply the light is working correctly now
the only issue i have is the fan not kicking in
is this just controlled my thermostat?
Offline gazareth
« Reply #6 on: 15 September 2013, 23:11 »
you may have a faulty switch in the radiator. if its fine on a run it wont be the thermostat.
Offline dubpirate
« Reply #7 on: 16 September 2013, 13:27 »
Yes I am putting it down to a faulty switch no before I got the car it just had a new loom put in the switch in my rad is a 2 pin the plug on the loom is 3 pin does this mean I just need a 3 pin switch ?
Offline gazareth
« Reply #8 on: 18 September 2013, 18:02 »
yeah that would be easiest way.
Offline taneshaleo
« Reply #9 on: 19 December 2013, 08:10 »
Sometimes it happens between the combustion chamber and the coolant system.
