Author Topic: Maintenance Section Index List  (Read 18124 times)
Offline Steve_PD
« on: 24 March 2012, 14:41 »
Ive compiled our maintenance section into a nice easy to read index...
(If you find any errors in the links let me know)
If you post a new topic in this section please let me or Rich know and we'll add it to the list, thanks  :smiley:
Buying a Mk4 Golf
Buying guide/common faults
Engine Codes & INFO
2.0 8V Facts
MK4 Tax Costs
Mk4 Tips & Tricks
Red I On Rear Badge?
Engine
GENREAL Service INFO
Can I Fit A Dump Valve?
Best Recirculating Valve for the 1.8T
1.8T Troubleshooting Guide
Faulty MAF
K03-K03S Turbo Numbers/Parts INFO
Engine Compression Check
HOW TO: Remove/Bypass the N249
HOW TO: Fit A Intank Fuel Pump
HOW TO: Throttle Body Clean
HOW TO: Replace the thermostat
HOW TO: Replace Temp Sender
HOW TO: Replace Pollen Filter
HOW TO: Fix Starter Motor squeal
HOW TO: Smooth Your Airbox/fit R32 DSG intake
HOW TO: Remove & Replace Fuel Injectors On A 1.8T
HOW TO: Fit Engine Mounts
HOW TO: Carbon canister delete
Milltek Exhaust INFO
Gearbox
Gearbox Data
G60 VR6 Clutch Upgrade
R32 Dog Bone Mount
HOW TO: TT Short Shifter Fitting & part numbers
HOW TO: Change/Top Up Gear Box Oil
Suspension
Coilovers or Springs
ARB Bush Size Codes
What FRONT ARB???
HOW TO: Replacing Bushes
HOW TO: Replace Rear Beam Bushes Without Removing Rear Beam
HOW TO: Replace Front & Rear Top Mounts
HOW TO: Fit a S3 Lower Strut Brace
HOW TO: Fit Lowering Springs
Brakes
312mm Brake Upgrade
HOW TO: Bleeding Brakes
If you find any other guides on your internet travels which would be helpful here drop myself or Rich a PM and we'll add them or if your competent enough right a guide when you do a job with pleny of photos and we'll add it to the maintenance section :smiley:
GolfGTI.co.uk and how to writers take no responsibility for any injury to yourself or any part failure!
« Last Edit: 20 April 2012, 23:09 by Steve_PD »
Offline Steve_PD
Re: Maintenance Section Index List
« Reply #1 on: 24 March 2012, 14:41 »
Continued. . . .
Wheels
Wheel/Tyre Fitments
Wheel INFO
Strange Road Noise
Exterior
Headlamp Washer Jet Part Number
HOW TO: Fit A Delock Kit & Part Numbers
HOW TO: Rear VW Sharan Badge Mod
HOW TO: Colour Code Standard Valances
HOW TO: Remove Rear Bumper
HOW TO: How to Change the boot handle / lock
Interior
Water In Passenger Footwell
HOW TO: Remove Interior Parts
HOW TO: Window Regualtor
HOW TO: Rear door card removal
HOW TO: Retrim your doorcards
HOW TO: Remove Your Seats
HOW TO: Remove Your Seats 2
Recaro Seat Fix
HOW TO: Remove The Steering Wheel
HOW TO: Fit New Interior Trim
HOW TO: Fit A Centre Armrest
HOW TO: Replace your chrome handbreak button
Interior Electrical
Reverse Light Wiring Fault
Wiper Motor & Boot Catch
Faulty Door Module
Bora Sport/Anniversary Clocks INFO
HOW TO: DIY W8 Light Mod
HOW TO: Install a Boost Gauge
HOW TO; Zero Boost Gauge Needle
HOW TO: Replace Heater Control Bulb
HOW TO: Fit Bora Vents & W8 & Part Numbers
HOW TO: Remove Radio & INFO On Radio Codes
Electrical
Bulb INFO
Fues Box & Relay Info
Check Alternator Fuses
Dash Lights
AGU Bosch M3.8.3 ECU Pin Out Information
AUM ECU Pin Outs
HOW TO : Replace Coil Pack Wiring
HOW TO: Joey Headlight Mod
HOW TO: Twin Foglight How To
HOW TO: Replace Brake Light Switch
HOW TO: OEM OEM Xenon Wiring Adapters & Rheostat Mod
Vag-Com/Vag-Tacho Related
Vag-Com Data Measuring guide
OBD Vag-Com Fault Codes
Vag-Com Fault Codes & User Location Database
HOW TO: Miles To Empty
HOW TO : Resync your keys & change the battery
New Key
Diesel
PD Deisel How To List
HOW TO: EGR & Intake Manifold Cleaning
Remapping
Engine Codes Explained & bExpected Powers From Remap
Miscellaneous
Online MOT History Checker
HOW TO: Reset Service Indicator
TPS Parts Price List
What a VAG part number means
Some other useful List of guides
'HOW TO' Guides
UK-MIVS
VWVortex
« Last Edit: 17 April 2012, 17:08 by Steve_PD »
jamie16v
« Reply #2 on: 27 March 2012, 21:52 »
Nice list!
