Golf mk2
Golf mk2 how to guides + info
Blue Temp Sender - What It does & How To Reset The ECU After Fitting (8V Digi)
Topic: Blue Temp Sender - What It does & How To Reset The ECU After Fitting (8V Digi) (Read 56072 times)
X4MGS
VAG Parts SNOB!!!
21 December 2011, 00:34 »
Blue Temp Sender
Can't take the credit for this - but I think its worth posting in here so peeps know what it does and how to reset the ECU after you have fitted a new one!
I would also suggest that you ONLY fit Genuine VW/VAG one's - They don't cost that much more than copy ones but do seem to last longer & what you save in the sender cost you can lose in fuel consumption when it stops working!!!!!
Stolen from wikipedia
Most of driveability issues can be traced back to a few issues:
Bad ECM earth/ground
Bad o2/lambda sensor earth/ground
Faulty Engine Coolant Temperature sensor (ECT/MFTS)
The engine coolant temperature sensor is located in the coolant flange,(under the distributor on the Polo Fox Coupe) on the front of the cylinder head (on transverse-engine vehicles).
The bad earth/ground can be traced to an essential ground/earth strap on the front upper transmission (Gearbox) bolt. Without this, the ECU tends to earth/ground elsewhere, causing a specific trace to burn out on the circuit board and killing the ECU. This causes the injectors to stay open constantly, flooding the engine.
Digifant engine management; Common issues that are indicative of a failed ECT/MFTS (Temp Sender) are:
Vehicle idles poorly
Engine sputters, might stall
Higher than normal fuel consumption
The part number for this sensor is '025 906 041 A' (always check with your Volkswagen dealer for the most updated part number).
The resistance of this unit is appriximately 3.2 Kohm at 10 degrees C.
If it measures open circuit this will explain erratic idle and throttle speeds especially when the engine is cold.
When replacing this sensor, it is important to also replace the O-ring ('N 903 168 02').
Once the new sensor has been installed, start the engine and disconnect the blue coolant temperature sensor.
Rev the engine through 3,000 rpm three times, each time allowing the throttle to close completely.
This clears the Digifant ECM fault memory.
Last Edit: 21 December 2011, 00:38 by X4MGS
For More Info Click To See;
My Thread On Here
Or
My Ebay Store!
X4MGS
VAG Parts SNOB!!!
Re: Blue Temp Sender - What It does & How To Reset The ECU After Fitting (8V Digi)
03 January 2012, 18:19 »
Blue temp sender can be tested by running the car and then unplugging it on tickover and you should hear the engine start to run erratically...
My Thread On Here
Or
My Ebay Store!
siddleg
18 March 2012, 12:18 »
cheers fir that bud ill give it a go
vii-cks
12 September 2012, 15:16 »
Can anyone please advise when you unplug it after fitting should the engine completely stall after poor running or should it remain running but just rough. Ours seems to cut out each time after I've changed it on my partners mk2.
Steve_B
22 August 2013, 12:32 »
Can also be tested by measuring resistance across the pins, as long as you know the temp. Link will show expected values:
http://vnc.thewpp.ca/stuff/bentley/ep0niks.ctech.ca/vw/eva2/FU01/ch7.2.1.html
apie2004
Here all the time
22 August 2013, 15:50 »
Does anyone know what the part number is of the older version of this sender which is threaded and white?
Golf mk2
