Car audio
10 Inch Sub recommendations...
4
5
8
Topic: 10 Inch Sub recommendations... (Read 14118 times)
Len
10k hero
Re: 10 Inch Sub recommendations...
Reply #20 on:
06 July 2011, 16:12 »
Well from recent checking think you will find that rules out most of the big boys!
Check out Infinity again or JBL
I think a Sony one is about £50 and say an Alpine 60/70 quid.
You'll have to scan through say Caraudiodirect and see what there is.
www.sas.org.uk
www.the-ace.org.uk
Dan n Nic
GTI forum regular
Reply #21 on:
07 July 2011, 15:26 »
Ok so Which is best from the following and come to that, what is the difference between the two Alpine's?
http://www.caraudiodirect.co.uk/vibe-blackair-10.html
http://www.caraudiodirect.co.uk/alpine-sws-1043d.html
http://www.caraudiodirect.co.uk/alpine-sws-1023d.html
Len
10k hero
Reply #22 on:
07 July 2011, 15:36 »
Cant see any difference other than numbers between those Alpines and mounting depth is fine!
However that Vibe is 150mm deep so no good if you only have 120mm!
www.sas.org.uk
www.the-ace.org.uk
Dan n Nic
GTI forum regular
Reply #23 on:
07 July 2011, 19:25 »
Ahhh, well spotted. Think I may have copied the wrong link.
B-chi
Reply #24 on:
07 July 2011, 22:04 »
Difference between Alpines is coil config.
1023d is dual 2ohm. Wired to either 1 or 4 ohms.
1043d is dual 4ohm. Wired to either 2 or 8 ohms.
You'll want to match the coil config to that of your amp.
Len
10k hero
Reply #25 on:
08 July 2011, 08:58 »
Thinking of changing my amp and sub, what should I go for B-chi?
Dont want top range.
Must be a 4 channel amp and 10 inch sub and think my max depth is 140mm.
www.sas.org.uk
www.the-ace.org.uk
B-chi
Reply #26 on:
12 July 2011, 07:43 »
Can't remember what comps your running Len? Infinities wasn't it!
What's ya budget?
Len
10k hero
Reply #27 on:
12 July 2011, 08:54 »
Yea Infinities in the rear but they off the HU.
Front door speakers are those SPL bass units.
Budget, well nothing silly, so a few hundred pounds say.
www.sas.org.uk
www.the-ace.org.uk
B-chi
Reply #28 on:
12 July 2011, 12:51 »
Diamond d1104.2 ex demo from cas looks to be good value. Should produce a nice background rumble.
Is it going in a sealed or ported enc?
Paired up to a jbl 1004e amp. 100w ea side to mids and 200w to the sub.
£75 for sub and £120 for amp.
That's the route I'd go for. Or look out for second hand.
Len
10k hero
Reply #29 on:
12 July 2011, 12:57 »
Its in a ported enclosure.
Having trouble locating that sub! Seems to be discontinued.
www.sas.org.uk
www.the-ace.org.uk
4
5
8
Car audio
