The garage
has anyone got a mk2 golf head light wiring diagram
Topic: has anyone got a mk2 golf head light wiring diagram (Read 2690 times)
gazman1011
Here all the time
if your not first, your last!
15 February 2011, 20:25 »
hi all, i need to re wire my head lights in my mk2, everything is cut, and i got burnt wires, has anyone got a mk2 headlight wireing diagram?
thanks gaz
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: has anyone got a mk2 golf head light wiring diagram
16 February 2011, 10:33 »
where is the hazard switch, dash or column? which bits are burnt out, bay side or behind the dash?
gazman1011
Here all the time
16 February 2011, 10:40 »
i got the hazard light in the dash, also its in the bay where i got some burnt and chopped together.
rubjonny
10k hero
16 February 2011, 13:42 »
http://vwtech.no-ip.info/downloads/jetta89.pdf
should do you. find the dim dip resistor and bin it, this could be the reason it melted in the 1st place. its the thing on driver side chassis leg about size of a packet of polos with a yellow wire out of each end. follow the wiring from it to the 2 pin plug, disconnect it then rip it off and bin
The garage
