Author Topic: ((((vr6 stock to vr6 track))))  (Read 48332 times)
Offline mmaattyyg
  • i need anger management as i dont take advice well
Re: ((((vr6 stock to vr6 track))))
« Reply #60 on: 07 January 2011, 00:27 »
does a roll cage for a vw golf mk3 vr6 3 door fit a 5 door ?
i need anger management as i dont take advise well ......
Offline SoundillusioN
« Reply #61 on: 07 January 2011, 00:35 »
I'm almost certain it does... depending on the type of cage it only becomes an issue if you want decent access to the rear via the back doors.
Offline mmaattyyg
« Reply #62 on: 07 January 2011, 00:59 »
can anyone else verify this as i dont want to go and spend £500 - £700 and it doesnt fit ! if it helps or makes a difference i dont want to use the rear doors at all.....
« Reply #63 on: 07 January 2011, 01:01 »
Where are you buying from and what type?
Offline mmaattyyg
« Reply #64 on: 07 January 2011, 01:07 »
this is what i was looking at ! have they made a mistake with the price or is it just a sh!t cage ? it says it for a 3 door tho ?
http://cgi.ebay.co.uk/AB-105P-156-OMP-ROLL-CAGE-VOLKSWAGEN-GOLF-GTi-MK3-91-98-/220720907811?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3363fdc623
« Reply #65 on: 07 January 2011, 08:47 »
It will fit fine but one small issue is that the center bars will not be in line with the pillars, when they really should be for strength reasons.
Offline mmaattyyg
« Reply #66 on: 07 January 2011, 08:59 »
So what do u reckon Wayne ? Could I get it and put some extra supports in after the cage is in !
Offline Diamond Hell
  • Opinions я Us
« Reply #67 on: 07 January 2011, 09:24 »
Those seats look shat and the harnesses look utter shat.
They're base-mount, so won't be proper shell seats and unless there's a hole for the crutch strap you're going to be limited to 4-point harnesses.
A 6-point cage won't have harness bars, so you'll still have a lot of work to get a harness bar welded into the cage.
I'd go for a grey/silver interior - it'll be hto as hell in a matt black interior in the summer and you only have four tiny little holes in the driver's window.
 :rolleyes:
Offline mmaattyyg
« Reply #68 on: 07 January 2011, 15:29 »
more rubbing down and spraying !
old bit of welding
mech and motor stripped out
managed to get one window in
« Reply #69 on: 07 January 2011, 15:34 »
Excellent progress.
