Author Topic: LEAK!  (Read 8483 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: LEAK!
« Reply #60 on: 16 October 2010, 18:44 »
your second sentence dont make sense..
and i dont have etka to answer the part number..
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
Re: LEAK!
« Reply #61 on: 16 October 2010, 18:58 »
also i got for that correct isn't it or do i need more
thanks
lol i don't even know i think i meant to put
"Also i got Four washers is that the correct amount if it isnt how many do i need ?"
My dislexia strikes again lol,  :laugh:
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline tech1889
  • Mk2 GTI FTW !!
Re: LEAK!
« Reply #62 on: 16 October 2010, 19:00 »
lol.. yer 4 sounds right 2 each side.. one each side of banjo..
Offline godsANGER
Re: LEAK!
« Reply #63 on: 16 October 2010, 19:01 »
Great  :grin:
Offline godsANGER
Re: LEAK!
« Reply #64 on: 20 October 2010, 22:54 »
picked up my washers today can some one check the part number as its not showing up on my ETKA
No. N 013 848 7   washer
thanks
can some one check this please
Offline godsANGER
Re: LEAK!
« Reply #65 on: 21 October 2010, 17:39 »
anyone?
Offline Mr_Orange
Re: LEAK!
« Reply #66 on: 21 October 2010, 18:28 »
That is the number on my ETKA  :wink:
N 013 848 7 (16x22mm)  £0.41 each.
You need two per banjo connection.
However....
There is another "Seal Ring" detailed that is a smaller size
N 013 849 5  (14x20mm) also £0.41 each
Seems a mixture of the two all over the rack.  Where is the leak again mate?
Build thread clicky
Offline godsANGER
Re: LEAK!
« Reply #67 on: 21 October 2010, 18:58 »
However....
thanks mate
myn were $0.51 each :lipsrsealed: got four should be auf shouldn't it
i believe its the unions between the high pressure pipes and pump
Offline Mr_Orange
Re: LEAK!
« Reply #68 on: 21 October 2010, 20:08 »
I'm a bit confused, but that image is one end of the rack no?  If that's the case there are two banjo connectors shown and one has the big seals and one has the small seals
At the pump there is only one set of the bigger ones and a hydraulic return pipe with a simple jubilee style clamp.
Looking at that leak, you are gunna need some of the smaller ones I mentioned too.  :undecided:
« Last Edit: 21 October 2010, 21:58 by Mr_Orange »
Build thread clicky
Offline godsANGER
Re: LEAK!
« Reply #69 on: 21 October 2010, 21:17 »
I'm a bit confused, but that image is one end of the rack no?  If that's the case there are two banjo connectors shown and one has the big seals and one has the small seals.  That is the same for each end of the rack.
ill have to get them orded then, yer that's the drivers side view of the rack
Thats the one i need yer?
