Author Topic: Engine mounts on mk4 1999 tdi 110  (Read 6360 times)
Offline ash159
« on: 04 February 2010, 11:45 »
Is it the same as this thread?
http://www.golfgtiforum.co.uk/index.php?topic=112925.0
Or is it completly differnt?
Offline Rhyso
Re: Engine mounts on mk4 1999 tdi 110
« Reply #1 on: 04 February 2010, 11:48 »
exactly the same :afro:
Offline ash159
« Reply #2 on: 04 February 2010, 11:49 »
thanking you :)
easy enough to do for a complete noob at all things taking cars apart lol?
Offline Rhyso
« Reply #3 on: 04 February 2010, 11:50 »
thanking you :)
although I didn't do mine myself it looked fairly straightforward and can be completed easily if you got a basic understanding of how a ratchet and socket works  :smiley:
Make sure you got a decent trolley jack to support the engine
Offline Rhyso
« Reply #5 on: 04 February 2010, 13:14 »
I've got the THS engine mounts and can't fault them at all.  Got the R32 dogbone mount but the THS one is much along the same lines
Cheaper than standard parts and better  :wink:
Don't forget the new bolts though as per the how-to link  :smiley:
Offline ash159
« Reply #6 on: 04 February 2010, 13:56 »
where can i get the new bolts from? (sorry lol)
Offline Rhyso
« Reply #7 on: 04 February 2010, 15:54 »
dealers.......
thats why the part numbers are in the thread  :tongue:
Offline ash159
« Reply #8 on: 07 February 2010, 18:12 »
when doing the lower dogbone mount, wheres the best place to put the jack to support the engine?
Always thought jacking it up on the sump was a no no?
Offline Rhyso
« Reply #9 on: 07 February 2010, 18:21 »
just get a block of wood to rest between the jack and the sump - the engine mounts will be taking the majority of the weight anyway.  Its only in case the engine may drop a little though you may get lucky and it won't move at all  :smiley:
