Author Topic: Replacement Rear Bushes  (Read 1741 times)
Offline scooby7161
« on: 09 January 2010, 16:59 »
I have a 1997 mk3 golf gti 8V lowered 80mm all round. Can anyone recommend good poly prop replacement bushes and a retailer that combines service and cost.
Re: Replacement Rear Bushes
« Reply #1 on: 09 January 2010, 19:27 »
Welcome to the site
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2 on: 10 January 2010, 09:42 »
are you talking about the rear beam bushes? get powerflex ones, try venom motorsport. they are a complete ball ache to fit.
Offline scooby7161
« Reply #3 on: 10 January 2010, 11:37 »
Thank you for the welcome Wayne.
Yes i did mean the rear beam bushes. Should i replace all the cars bushes in one go or can it be done over a couple of weeks.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #4 on: 10 January 2010, 12:19 »
it can be done, but if you decide to do the entire car its a lot of work. i did mine off the car as i had the engine out and that was hard enough. just be prepared.
it really does tighten the whole car up, and is worth it in the long run. I would say the rear beam bushes were the hardest to do. i had to bore out the hole in the rear beam for the bush a lot so it would fit. even then it was a very tight fit!
if you are going to do any in the front, i would do them at the same time. arb bushes and wishbone bushes. take a look on the powerflex site for a diagram of there products on a mk3.
Offline harlemex
« Reply #5 on: 11 January 2010, 15:48 »
You say you had to bore out the hole in the rear beam and even then it was tight. Thats really odd, I fitted mine and they simply pushed in using my fingers. They were still a tight fit but using the supplied grease went in with complete ease. I am wondering if you got the wrong ones as there are 2 sizes(4 or 5 stud)???
Offline LazyLunatic
  • MK3 20VT Project
« Reply #6 on: 12 January 2010, 09:25 »
powerflex only do 1 size i thought.......
anyway its all good, they are in there nice and snug, so its doesnt really matter.
Offline scooby7161
« Reply #7 on: 13 January 2010, 21:58 »
Many thanks for your help and advice. I have a garage that have quoted me £100 to fit rears so i will go with them. The fronts I will get done next time.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #8 on: 14 January 2010, 09:20 »
they are hard to fit, but £100 seems quite steep. with the price of bushes, thats £150 for your rear beam to be polybushed......
get stuck and do it yourself, even if it takes you a day, saves you £100! just make sure you got a file and hammer, etc
