Author Topic: TUNING The 8v Camshaft Thread..  (Read 92411 times)
Offline axewielder
  • 95 dragon 8v
Re: The Camshaft 8v Information Thread..
« Reply #10 on: 14 September 2009, 19:55 »
here ya go, i can look for other engine codes if you want, this is straight from vw so should be accurate
valve timing at 1mm valve lift
engine code                           ADY          AGG             2E
Inlet opens after TDC               3               1               3
inlet closes after BDC              44              37              44
exhaust opens before BDC       37               41             37
exhaust closes before TDC       -                5                -
exhaust closes after TDC         4                -                4
« Last Edit: 14 September 2009, 20:39 by axewielder »
Offline bored_Welsh_lad
« Reply #11 on: 14 September 2009, 20:44 »
how do you turn that information into cam duration then?? i thought those figures with primarily to do with cam overlap issues and firing sequence i suppose...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline axewielder
  • 95 dragon 8v
« Reply #12 on: 14 September 2009, 21:52 »
lol thought you knew!
for ady+2e, inlet duration = 3+44+180= 227  exhaust=37+4+180= 221
agg inlet=1+37+180=228  exhaust =41+180-5=216
i think thats how it works, havent really read ure post properly though
can get other engine code spec if wanted
VW BUSH
« Reply #13 on: 14 September 2009, 22:06 »
MK2 PB engine :smiley:
Offline tronds
« Reply #14 on: 26 September 2009, 22:00 »
just trying to find out the standard camshaft duration on an 8v because i dont think its anywhere near 270 and stumbled across this lot...
Did you find any more information on camshafts? I am thinking of identification marks.
I am trying to identify a G60 camshaft. http://forums.vwvortex.com/zerothread?id=4572272
I will try to mount it into a head without valves and try to measure lift and duration. Not sure of what kind of accuracy I get, but I will try.
Offline axewielder
  • 95 dragon 8v
« Reply #15 on: 28 September 2009, 09:43 »
i couldnt find info on the pb cam, was f**king up, i can get id marks for some engines, will look when home later, engine codes would help
Offline tronds
« Reply #16 on: 28 September 2009, 10:34 »
I found info about the ID marks on the G60 cam. Just have a look at the thread at VWvortex.
If you have ID-marks for other camshaft, it would be great. I am trying to build a information table where you can find data on as many camshafts as possible.
Offline axewielder
  • 95 dragon 8v
« Reply #17 on: 28 September 2009, 10:40 »
if you whack up some engine codes ill see what i can find
Offline tronds
« Reply #18 on: 28 September 2009, 10:48 »
I have collected some info about camshaft.
Some comes from this thread, and the rest I have dug up for camshaft catalogs.
Information about powerband, HP increase and identity markings would be great.
http://www.solem.nu/G60/camshafts.pdf
Offline axewielder
  • 95 dragon 8v
« Reply #19 on: 29 September 2009, 23:28 »
  G60 engine PG
→ Fig.4    Camshaft identification, valve timing
Identification
◆ Cam base diameter: a = 34 mm ø
◆ Identification by stamped numbers and letters between inlet and exhaust cams:
    No. 1 cylinder -arrow I-: A
    No. 3 cylinder -arrow II: 026
Valve timing at 1 mm valve lift
Inlet opens:
 TDC
Inlet closes after BDC:
 40 °
Exhaust opens before BDC:
 40 °
Exhaust closes:
 TDC
« Last Edit: 29 September 2009, 23:46 by axewielder »
